Main screen
This dot informs the pilot of the connectivity status, which can be either green or red, depending on its activity.
- My position: confirms if the mobile device's GPS is properly transmitting its position.
If one or more of your fellow pilots (included in your SafeSky fellow pilots list - see the "Settings" chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages.
Create a squadron
- Click on followed by "Invite" to directly reach out to the pilots you want to join your squadron.
- The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -3,500ft / +3,500ft relative to your flight altitude.
- Airport (PREMIUM feature): Filters the types of airports you want to be displayed on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
Here you will find a wealth of resources that walk you through the App's features and capabilities.
- Status:
Cloud Base Altitude in feet
Horizontal visibility in kilometres
