Frequently Asked Questions
Configuration
Absolutely!
You have two options:
See also here
That's simple.
It's essential to have the same unique ICAO hexadecimal code on all your devices. To do so, simply enter it in SafeSky under "Settings > My aircraft > Callsign > Turn on the Transponder button", and the updated code will automatically appear.
It's important to configure all your external devices (such as FLARM, PilotAware, SkyEcho, Stratux, etc.) with the same hex code and address type set to "ICAO"
See also here
That's easy.
See also here
Using EasyVFR
If you're using EasyVFR, you probably forgot to add your callsign to EasyVFR configuration as described on this link.
Functioning
  • In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
  • SafeSky's community is mostly pilots flying in E and G airspace classes up to 5,000 feet AGL. Above that, pilots usually fly in a different airspace.
SafeSky is a tool designed to create harmony in the sky for all users, including paragliders who are the most vulnerable users due to the slow speed and closeness with fast aircraft like ULMs and GA planes. With SafeSky, tyou can improve safety  simply by having your phone in your pocket. As a paramotor or paragliding pilot, you can receive alerts about surrounding fast aircraft. Additionally, SafeSky integrates traffic information from various sources, including dedicated apps like Gaggle, eVario, and XCTrack, as well as external devices such as SkyTraxx and Air3. By sharing in-flight positions through SafeSky's collaborative platform, paragliders, paramotor pilots and GA pilots can receive respective SafeSky traffic alerts.
That's possible.
It is very low.
  • Plug in a charger
How to unsubscribe?
Why is this beneficial?
How to set it up?
  1. Open the browser on your computer or SmartTV.
  2. Navigate to SafeSky Live Traffic. (https://live.safesky.app)
  3. Zoom into your airfield’s location. The system will remember this setting for future access.
  4. Customise your view by filtering for specific traffic altitudes, changing the map theme, and more.
Sharing Premium Licenses Between EasyVFR and SafeSky
EasyVFR to Safesky
To transfer your EasyVFR Premium license to SafeSky, follow the simple steps described on this link.
SafeSky to EasyVFR
1. Go to Traffic Sharing from the SafeSky app menu.
2. Be sure Enable Traffic Sharing is enabled.
3. Tap on the select app line.
4. Select EasyVFR.
5. Tap on Connect with EasyVFR.
Issue
Solution
  1. Check your device's time settings:
    • On iOS, go to Settings > General > Date & Time.
    • On Android, go to Settings > System > Date and time.
  2. Enable automatic time setting:
    • Ensure Set Automatically is turned on. If it is already on, toggle it off and then back on to resynchronize your device's time with the network.
  3. Verify the accuracy of the time:
    • Compare your device's time with other devices to ensure it is correct.
Compatibility
Is SafeSky compatible with SDVFR and SDVFR Next?
Yes.
SafeSky sends traffic via GDL 90 to SD VFR.
Plan PREMIUM feature.
  • Android 6 + 2GB RAM minimum
  • Apple iOS 13 minimum
See also here
