How it works?
The principle
SafeSky is a mobile application designed for sharing real-time in-flight traffic information. Using the GPS chip of your mobile device, the SafeSky App sends your position to our servers, which then transmit it to other users of the application.
In addition to the traffic generated by the application itself, SafeSky aggregates traffic information obtained through its various partnerships or available from numerous ground stations managed and maintained by individuals, perhaps even by you. These stations provide highly precise positions of aircraft emitting ADS-B, Flarm, or OGN signals. SafeSky collects all this valuable information to add it to its own traffic data and provide you with the most comprehensive in-flight traffic information.
The visual below illustrates how SafeSky works:
The internet
In Europe, the internet coverage is generally excellent. Based on our data since our existence, SafeSky has an 80% success rate for data transmission up to 5,000 feet. Although there may be occasional spots with no coverage, SafeSky will automatically reconnect once the connection is restored. Moreover, SafeSky's primary pilot base consists of pilots flying in E and G airspace classes, up to 5,000 feet AGL. Beyond that altitude, pilots typically operate in different airspace categories.
Crossing a border requires switching to a new mobile network operator, a process known as roaming. This usually results in a brief network loss (about 1 or 2 minutes) as the mobile connects to the new operator, similar to what happens when driving across borders.
