Main Screen
xxx explained later
  • Status:
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet
Radar screen
    Internet: indicates the status and activity of the internet connection. SafeSky: provides information about the last exchange with SafeSky servers. My Position: confirms if the mobile device's GPS is properly transmitting its position. <Navigation Software>: confirms the choice and connection to the selected navigation software in the application Settings.
    Press this button during flight if you find yourself in a situation that could lead to an emergency landing. Simply activating SAR will trigger a series of actions detailed in the Settings section.
    This feature is active in both the free and Premium versions.
    If one or more of your fellow pilots (included in your SafeSky fellow pilots list - See the Settings chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if you wish.
      Up to +/- 0.3 nautical miles, approximately +/- 0.5 km Up to +/- 3 nautical miles, approximately +/- 5.5 km Up to +/- 8 nautical miles, approximately +/- 15 km Up to +/- 30 nautical miles, approximately +/- 55 km
        Traffic: Shown as icons representing the type of visible aircraft, along with their call sign and relative altitude compared to your current position in flight. For example, +04 indicates that the traffic is 400 feet higher than your position, while -12 means it is 1,200 feet lower.
        Expliquer map
