Main Screen
xxx explained later
- Status:
Cloud Base Altitude in feet
Only the PREMIUM version allows you to create more than one aircraft.Â
Radar screen
If you forget to stop the flight while grounded, the SafeSky application will automatically stop after 10 minutes of aerial inactivity.Â
At the bottom of this screen, the red "STOP" button allows you to end your flight and stop sharing your position. Â Â
Expliquer map
