User Interfaces
Main screen
  • Status:
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet
This section is where you can manage all of SafeSky's Settings. There is a dedicated chapter for it.
Radar screen
Expliquer map
