User Interfaces
Main screen
If one or more of your fellow pilots (included in your SafeSky fellow pilots list - see the Settings chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if you wish.
  • Status:
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet
This section is where you can manage all of SafeSky's Settings. There is a dedicated chapter for it.
Radar screen
Expliquer map
