User Interfaces
Main screen
- Status:
Cloud Base Altitude in feet
Radar screen
IfBy trafficpressing isthe toomap closeicon toat yourthe position,top an orange or red cone will precisely alert youright of itsthe position. An audible alert can also be configured if you are using a Bluetooth headset.
Switching to map mode
Depending on your Settings,screen, you can switch to map mode. This view can give you a better awareness of the surrounding traffic (Situational Awareness). Similarly, in map mode, you will have the option to switch back to radar mode. Switching to map mode does not stop the sharing of your position.
