User Interfaces
Main screen
If one or more of your fellow pilots (included in your SafeSky fellow pilots list - see the Settings chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.you wish.
- Status:
Cloud Base Altitude in feet
Radar screen
If one or more of your fellow pilots (included in your SafeSky fellow pilots list - See the Settings chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.you wish.
Switching to map mode
