User Interfaces
Main screen
- Status:
Cloud Base Altitude in feet
Radar screen
My Positionposition
My Fellowfellow Pilotspilots
Cancel Alertsalerts
Stop your Flightflight
Radar Zoomzoom
Switching to Mapmap Modemode
