User Interfaces
Main screen
  • Status:
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet
This section is where you can manage all of SafeSky's Settings. There is a dedicated chapter for it.
Radar screen
  • Traffic: Shown as icons representing the type of visible aircraft, along with their call sign and relative altitude compared to your current position in flight. For example, +04 indicates that the traffic is 400 feet higher than your position, while -12 means it is 1200 feet lower.
Switching to map mode
