User Interfaces
Main screen
  • Status:
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet
This section is where you can manage all of SafeSky's settings,Settings. andThere we have dedicatedis a dedicated chapter tofor it below.it.
Radar screen
This circledot informs the pilot of the connection status, which can be either green or red, depending on its activity.
By clicking on thisthe cercle,dot, a sub-window appears with additional information:
  • Internet: indicates ifthe status and activity of the internet connection is active.connection.
  • SafeSky: informsprovides information about the receptionlast ofexchange with SafeSky traffic via mobile internet.servers.
  • My Position: informsconfirms aboutif the sharing of your position via mobile internet.device's PressGPS "TAKEis OFF"properly totransmitting activate the sharing of yourits position.
  • <Navigation Software>: confirms the choice and connection to the selected navigation software in the application .
Press this button during flight if you find yourself in a complicated situation that could lead to an emergency landing. Simply activating SAR will trigger a series of actions detailed in the Settings paragraph.
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
  • Traffic: Shown as icons representing the type of visible aircraft, along with their call sign and relative altitude compared to your current position in flight. For example, +04 indicates that the traffic is 400 feet higher than your position, while -12 means it is 1200 feet lower.
Switching to Map Mode
