User Interfaces
Main screen
- Status:
Cloud Base Altitude in feet
This is essential, as your position will not be shared with the SafeSky community without pressing "TAKE OFF"."
If you wish to transfer traffic to a navigation software (SkyDemon, ForeFlight, or others), it is imperative to press "TAKE OFF,"OFF" even while on the ground.grounded. This action activates traffic sharing with compatible navigation software. Without "TAKE OFF,"OFF" there will be no traffic on the navigation software's maps.
Radar screen
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
Switching to Map Mode
