User Interfaces
Main screen
- The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -
2000ft3,500ft / +2000ft3,5000ft relative to your flight altitude. - The following three filters are:
- Transponder: Filters the types of transponders aggregated by
SafeSky,SafeSky you want to be displayed, including ADS-B, ADS-L, ASTERIX, FANET, FLARM, FLYING NEURONS, FLYMASTER, INREACH, MICROTRAK, MODE-S, NAVITER, OGN TRACKER, PILOT AWARE, REMOTE ID (Recreational Drones), SAFESKY, SPIDER, SPOT, XC GUIDE, XC TRACK. This list of transponders aggregated by SafeSky is continuously updated. - Airport: Filters the types of airports
visibleyou want to be displayed on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
The trafficTraffic displayed in blackrepresentsis traffic fromacompatibletransponder.aggregated information sources. Traffic displayed in blue is trafficexclusivelyfromvisibleSafeSkyin SafeSky.sources.
This feature provides access to weather information on the map, based on the latest METARsMETAR from airfields. The following information is accessible:
Statut :Status:- 🟢 VFR (Visual Flight Rules)
Cloud Base Altitude in
feet.feet -
Wind direction and speed in
knots.knots -
Horizontal visibility in
kilometers.kilometers
Radar screen
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
Switching to Map Mode
