User Interfaces
Main screen
  • The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -2000ft / +2000ft relative to your flight altitude.
    • Aircraft: Filters the type of aircraft to be displayed.
    • Transponder: Filters the types of transponders aggregated by SafeSky, including ADS-B, ADS-L, ASTERIX, FANET, FLARM, FLYING NEURONS, FLYMASTER, INREACH, MICROTRAK, MODE-S, NAVITER, OGN TRACKER, PILOT AWARE, REMOTE ID (Recreational Drones), SAFESKY, SPIDER, SPOT, XC GUIDE, XC TRACK. This list of transponders aggregated by SafeSky is continuously updated.
    • Airport: Filters the types of airports visible on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
  • The traffic displayed in black represents traffic from a transponder. Traffic displayed in blue is traffic exclusively visible in SafeSky.
Center position on map
  • Statut :
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet.
  • Wind direction and speed in knots.
  • Horizontal visibility in kilometers.
Radar screen
  • Internet: indicates if the internet connection is active.
  • SafeSky: informs about the reception of SafeSky traffic via mobile internet.
  • My Position: informs about the sharing of your position via mobile internet. Press "TAKE OFF" to activate the sharing of your position.
  • <Navigation Software>: confirms the choice and connection to the selected navigation software in the Settings.
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
  • Traffic: Shown as icons representing the type of visible aircraft, along with their call sign and relative altitude compared to your current position in flight. For example, +04 indicates that the traffic is 400 feet higher than your position, while -12 means it is 1200 feet lower.
Switching to Map Mode
