User Interfaces
Main screen
Center position on map
Cloud Base Altitude in feet.
Radar screen
Internet:Internet: indicates if the internet connection is active.SafeSky:SafeSky: informs about the reception of SafeSky traffic via mobile internet.- My
Position:Position: informs about the sharing of your position via mobile internet. Press "TAKE OFF" to activate the sharing of your position. - <Navigation Software>: confirms the choice and connection to the selected navigation software in the Settings.
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
Switching to Map Mode
