User Interfaces
Main screen
Internet:Internet: indicates the status and activity of the internet connection.SafeSky:SafeSky: provides information about the last exchange with SafeSky servers.- My
Position:Position: confirms if the mobile device's GPS is properly transmitting its position. - <Navigation Software>: confirms the choice and connection to the selected navigation software in the application Settings.
Center position on map
Cloud Base Altitude in feet.
Radar screen
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
Switching to Map Mode
