User Interfaces
Main screen
This circledot informs the pilot of the connection status, which can be either green or red, depending on its activity.
By clicking on thisthe circle,dot, a sub-window appears with additional information:
Center position on map
Cloud Base Altitude in feet.
Radar screen
My Position
My Fellow Pilots
Cancel Alerts
Stop your Flight
Radar Zoom
Switching to Map Mode
