User Interfaces
Main screen
Center position on map
Cloud Base Altitude in feet.
Finally... the take-off button!
Press this button during flight if you find yourself in a complicated situation that could lead to an emergency landing. Simply activating SAR will trigger a series of actions detailed in the PreferencesSettings paragraph.
My Position
My Fellow Pilots
If one of your fellow pilots (included in your SafeSky fellow pilots list - See the PreferencesSettings chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.
Cancel Alerts
Stop your Flight
Radar Zoom
The radar is represented by concentric circles indicating the information zone based on 4 different zoom levels (see above). In the PreferencesSettings, the radar can be configured in nautical miles (NM) or kilometers (kms).
Switching to Map Mode
Depending on your PreferencesSettings, you can switch to map mode. This view can give you a better awareness of the surrounding traffic (Situational Awareness). Similarly, in map mode, you will have the option to switch back to radar mode. Switching to map mode does not stop the sharing of your position.
