User Interfaces
Main screen
  • <Navigation Software>: confirms the choice and connection to the selected navigation software in the application Preferences.
If one of your fellow pilots (included in your SafeSky fellow pilots list - see the Preferences chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.
  • The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -2000ft / +2000ft relative to your flight altitude.
    • Aircraft: Filters the type of aircraft to be displayed.
    • Transponder: Filters the types of transponders aggregated by SafeSky, including ADS-B, ADS-L, ASTERIX, FANET, FLARM, FLYING NEURONS, FLYMASTER, INREACH, MICROTRAK, MODE-S, NAVITER, OGN TRACKER, PILOT AWARE, REMOTE ID (Recreational Drones), SAFESKY, SPIDER, SPOT, XC GUIDE, XC TRACK. This list of transponders aggregated by SafeSky is continuously updated.
    • Airport: Filters the types of airports visible on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
  • The traffic displayed in black represents traffic from a transponder. Traffic displayed in blue is traffic exclusively visible in SafeSky.
Center Position on Map
  • Statut :
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet.
  • Wind direction and speed in knots.
  • Horizontal visibility in kilometers.
Select Your Aircraft
Finally... the take-off button!
Preferences
Connection Status
  • Internet: indicates if the internet connection is active.
  • SafeSky: informs about the reception of SafeSky traffic via mobile internet.
  • My Position: informs about the sharing of your position via mobile internet. Press "TAKE OFF" to activate the sharing of your position.
  • <Navigation Software>: confirms the choice and connection to the selected navigation software in the Preferences.
Press this button during flight if you find yourself in a complicated situation that could lead to an emergency landing. Simply activating SAR will trigger a series of actions detailed in the Preferences paragraph.
My Position
My Fellow Pilots
If one of your fellow pilots (included in your SafeSky fellow pilots list - See the Preferences chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.
Cancel Alerts
Stop your Flight
Radar Zoom
The radar is represented by concentric circles indicating the information zone based on 4 different zoom levels (see above). In the Preferences, the radar can be configured in nautical miles (NM) or kilometers (kms).
  • Traffic: Shown as icons representing the type of visible aircraft, along with their call sign and relative altitude compared to your current position in flight. For example, +04 indicates that the traffic is 400 feet higher than your position, while -12 means it is 1200 feet lower.
Switching to Map Mode
Depending on your Preferences, you can switch to map mode. This view can give you a better awareness of the surrounding traffic (Situational Awareness). Similarly, in map mode, you will have the option to switch back to radar mode. Switching to map mode does not stop the sharing of your position.
