User Interfaces
Main Screenscreen
ConnectionsConnection tatusstatus
- <Navigation Software>: confirms the choice and connection to the selected navigation software in the application Preferences.
If one of your fellow pilots (included in your SafeSky fellow pilots list - see the Preferences chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.
Center Position on Map
Cloud Base Altitude in feet.
Select Your Aircraft
Finally... the take-off button!
Preferences
Connection Status
- <Navigation Software>: confirms the choice and connection to the selected navigation software in the Preferences.
Press this button during flight if you find yourself in a complicated situation that could lead to an emergency landing. Simply activating SAR will trigger a series of actions detailed in the Preferences paragraph.
My Position
My Fellow Pilots
If one of your fellow pilots (included in your SafeSky fellow pilots list - See the Preferences chapter) is in flight, you can easily locate them on the map and send them pre-recorded messages if needed.
Cancel Alerts
Stop your Flight
Radar Zoom
The radar is represented by concentric circles indicating the information zone based on 4 different zoom levels (see above). In the Preferences, the radar can be configured in nautical miles (NM) or kilometers (kms).
Switching to Map Mode
Depending on your Preferences, you can switch to map mode. This view can give you a better awareness of the surrounding traffic (Situational Awareness). Similarly, in map mode, you will have the option to switch back to radar mode. Switching to map mode does not stop the sharing of your position.
