Main Screen
Create a squadron
  • Fill in the requested information (only the squadron name is required) - Press "Create" at the top right. The shortname will appear on the map next to the aircraft's callsign.
  • Click on Fichier 1LogoThirdParties.png followed by "Invite" to directly reach out to the pilots you want to join your squadron.
  • Your fellow pilots will receive the invitation to join your squadron directly on the SafeSky application and can accept or decline it.
  • Once your squadron is created, press "TAKE OFF".
  • There will be no in-flight alerts between the members of the same squadron.
  • The aircraft icons of your fellow pilots will take on the colour of your squadron, that other pilots using SafeSky will also see to realise you are flying together.
  • On the screen, the squadron icon will also take on the chosen colour for your squadron.
  • By pressing this icon, at any time, you will have access to a menu allowing you to localise your friends, send them a message through intercom, or manage your squadron (adjust or delete).
  • The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -3,500ft / +3,500ft relative to your flight altitude.
    • Airport (Premium feature): Filters the types of airports you want to be displayed on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
  • Status:
    • 🟢 VFR (Visual Flight Rules)
    • Gray colour = METAR not updated for over 30 minutes
  • Cloud Base Altitude in feet
  • Horizontal visibility in kilometres
This section is where you can personalise all of SafeSky's Settings. There is a dedicated chapter for it.
If you wish to transfer traffic to a navigation software (SkyDemon, ForeFlight, or others), it is imperative to press "TAKE OFF" even while grounded. This action indeed activates traffic sharing with compatible navigation software. Without "TAKE OFF" there will be no traffic visible on the navigation software's maps.
