Main Screen
Create a squadron
- Click on
- The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -3,500ft / +3,500ft relative to your flight altitude.
- Airport (Premium feature): Filters the types of airports you want to be displayed on the map (Airport, Ultralight Base, Hydrobase, Gliders, etc.).
- Status:
Cloud Base Altitude in feet
Horizontal visibility in kilometres
