Main Screen
Create a squadron
- Click on
- The RADAR filter is important as it provides the visible traffic range in relation to your position. For example, in this case, the radar-visible traffic will be within the range of -3,500ft / +3,
5000ft500ft relative to your flight altitude. - The following three filters are:
- Status:
Cloud Base Altitude in feet
Horizontal visibility in kilometres
