Main Screen
Create a squadron
Inviting fellow pilots to join your squadron during a flight allows you to display the avatars of the aircraft in a specific color,colour, making them more visible on the map.
- Click on
On the screen, the squadron icon will also take on the chosen
colorcolour for your squadron. -
- Status:
Cloud Base Altitude in feet
