Main Screen
Create a squadron
- Click on
- Status:
Cloud Base Altitude in feet
This button displays the call signcallsign of the last used aircraft. If no action is taken, this aircraft will be used for the next flight. By clicking on this button, you can access the aircraft configuration page, giving you the option to choose another previously created aircraft or create a new one ("Manage my aircraft").
