Main Screen
Create a squadron
Inviting fellow pilots to join your squadron during a flight allows you to display the avatars of the aircraft in a specific color, making them more visible on the map, and also disables proximity alerts between the aircraft in the same squadron.map.
- Click on
By pressing this icon, at any time, you will have access to a menu allowing you to locate your friends, send them a message through intercom, or manage your squadron (adjust or delete).
- Status:
Cloud Base Altitude in feet
