Main Screen
Create a squadron
- Click on
Once your squadron is created, press "TAKE OFF."
By pressing this icon, at any time, you will have access to a menu allowing you to locate your friends, send them a message through intercom, or manage your squadron (adjust or delete).
- Status:
Cloud Base Altitude in feet
