Main Screen
ChatGPT
  • Fill in the requested information (only the squadron name is required) - Press "Create" at the top right. The shortname will appear on the map next to the aircraft's callsign.
  • Click on Pilot + Invite_Plan de travail 1.png followed by "Invite" to directly reach out to the pilots you want to join your squadron.
  • Your fellow pilots will receive the invitation to join your squadron directly on the SafeSky application and can accept or decline it.
  • Once your squadron is created, press "TAKE OFF."
By pressing this icon, at any time, you will have access to a menu allowing you to locate your friends, send them a message through intercom, or manage your squadron (adjust or delete).
  • Status:
    • 🟢 VFR (Visual Flight Rules)
  • Cloud Base Altitude in feet
