Main Screen
- Click on
Once your squadron is created, press "TAKE OFF." There will be no in-flight alerts between the members of the same squadron. The aircraft icons of your fellow pilots will take on the colour of your squadron,
and thisapplies even tothat other pilots using SafeSky.will also see to realise you are flying together. -
On the screen, the squadron icon will also take on the chosen color for your squadron. By pressing this icon, at any time, you will have access to a menu allowing you to locate your friends, send them a message through intercom, or manage your squadron (adjust or delete).
- Status:
Cloud Base Altitude in feet
