HMAC Auth SDK for Kotlin
SafeSky HMAC Authentication SDK for Kotlin
Kotlin SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
API Endpoint: All requests use https://uav-api.safesky.app. Each API key is associated with either a sandbox or production environment. The gateway automatically routes your request to the correct backend based on the environment configured for your API key.
Installation
Gradle (Kotlin DSL)
Add to your build.gradle.kts:
dependencies {
    implementation("com.safesky:hmac-auth:1.0.0")
    implementation("org.jetbrains.kotlinx:kotlinx-serialization-json:1.6.2")
Maven
Add to your pom.xml:
<dependency>
    <groupId>com.safesky</groupId>
    <artifactId>hmac-auth</artifactId>
    <version>1.0.0</version>
</dependency>
<dependency>
    <groupId>org.jetbrains.kotlinx</groupId>
    <artifactId>kotlinx-serialization-json-jvm</artifactId>
    <version>1.6.2</version>
</dependency>
Quick Start
import com.safesky.authentication.SafeSkyHmacAuth
import java.net.URI
import java.net.http.HttpClient
import java.net.http.HttpRequest
import java.net.http.HttpResponse
fun main() {
    // Your SafeSky API key
    val apiKey = "YOUR_SAFESKY_API_KEY_HEREHere"
    val headers = SafeSkyHmacAuth.generateAuthHeaders(
        apiKey,
        "GET",
        "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908"
    // Make authenticated request
    val client = HttpClient.newHttpClient()
    val requestBuilder = HttpRequest.newBuilder()
        .uri(URI("https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908"))
        .GET()
    headers.toMap().forEach { (key, value) ->
        requestBuilder.header(key, value)
    val response = client.send(requestBuilder.build(), HttpResponse.BodyHandlers.ofString())
    println(response.body())
Usage Examples
The SDK includes 4 complete examples in Example.kt:
Example 1: GET Request
import java.net.URI
fun getNearbyAircraft() {
    val apiKey = "YOUR_SAFESKY_API_KEY_HERE"
    val url = "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000"
    // Generate auth headers
    val authHeaders = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "GET", url)
    // Make request
        .uri(URI(url))
        .GET()
        .header("Content-Type", "application/json")
    authHeaders.toMap().forEach { (key, value) ->
    println("Status: ${response.statusCode()}")
Example 2: POST Request
import kotlinx.serialization.json.*
import java.net.URI
fun postUavPosition() {
    val url = "https://uav-api.safesky.app/v1/uav"
    // Build request body
    val bodyData = buildJsonArray {
        addJsonObject {
            put("id", "my_uav_001")
            put("altitude", 110)
            put("latitude", 50.69378)
            put("longitude", 4.39201)
            put("last_update", System.currentTimeMillis() / 1000)
            put("status", "AIRBORNE")
            put("call_sign", "Test UAV")
            put("ground_speed", 10)
            put("course", 250)
            put("vertical_rate", 5)
    val body = bodyData.toString()
    val authHeaders = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "POST", url, body)
    // Make request
        .uri(URI(url))
        .POST(HttpRequest.BodyPublishers.ofString(body))
fun postAdvisory() {
    val url = "https://uav-api.safesky.app/v1/advisory"
    val timestamp = System.currentTimeMillis() / 1000
    val bodyData = buildJsonObject {
        put("type", "FeatureCollection")
        putJsonArray("features") {
            addJsonObject {
                put("type", "Feature")
                putJsonObject("properties") {
                    put("id", "my_advisory_id1")
                    put("max_altitude", 111)
                    put("last_update", timestamp)
                    put("call_sign", "Advisory test with polygon")
                    put("remarks", "Inspection powerlines")
                putJsonObject("geometry") {
                    put("type", "Polygon")
                    putJsonArray("coordinates") {
                        addJsonArray {
                            add(buildJsonArray { add(4.3948); add(50.6831) })
                            // ... more coordinates ...
            addJsonObject {
                    put("id", "my_advisory_id2")
                    put("max_altitude", 150)
                    put("max_distance", 500)
                    put("call_sign", "Advisory test with a point")
                    put("remarks", "Inspection rails")
                    put("type", "Point")
                        add(4.4)
                        add(50.7)
import java.net.URI
fun manualAuthentication() {
    // Step 1: Derive KID
    val kid = SafeSkyHmacAuth.deriveKid(apiKey)
    println("KID: $kid")
    // Step 2: Derive HMAC key
    val hmacKey = SafeSkyHmacAuth.deriveHmacKey(apiKey)
    val timestamp = SafeSkyHmacAuth.generateTimestamp()
    val nonce = SafeSkyHmacAuth.generateNonce()
    val canonicalRequest = SafeSkyHmacAuth.buildCanonicalRequest(
        "GET",
        "/v1/uav",
        "lat=50.6970&lng=4.3908",
        "api.safesky.app",
        timestamp,
        nonce,
    // Step 5: Generate signature
    val signature = SafeSkyHmacAuth.generateSignature(canonicalRequest, hmacKey)
    println("Signature: $signature")
API Reference
Main Object: SafeSkyHmacAuth
Singleton object providing HMAC authentication functions.
generateAuthHeaders(apiKey, method, url, body = "")
Parameters:
  • url (String): Full request URL including protocol, host, path, and query string
  • body (String, optional): Request body for POST/PUT requests (default: empty string)
Returns: SafeSkyAuthHeaders data class containing all required headers
    "YOUR_SAFESKY_API_KEY_HERE",
    "POST",
    "https://uav-api.safesky.app/v1/uav",
    Json.encodeToString(data)
Data Class: SafeSkyAuthHeaders
Container for authentication headers.
Properties:
  • authorization (String): Authorization header value
  • xSsDate (String): X-SS-Date header value
  • xSsNonce (String): X-SS-Nonce header value
  • xSsAlg (String): X-SS-Alg header value
Methods:
  • toMap() → Map<String, String>: Convert headers to map for HTTP requests
Helper Functions
deriveKid(apiKey) → String
deriveHmacKey(apiKey) → ByteArray
generateNonce() → String
Generates a cryptographically secure nonce (UUID format).
generateTimestamp() → String
Format: YYYY-MM-DDTHH:MM:SS.sssZ
buildCanonicalRequest(...) → String
Parameters:
  • path (String): Request path
  • queryString (String): Query string without leading ?
  • host (String): Host header value
  • timestamp (String): ISO8601 timestamp
  • nonce (String): Unique nonce
  • body (String): Request body
generateSignature(canonicalRequest, hmacKey) → String
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname:port
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Running Examples
## Using Gradle
./gradlew run
## Or with Gradle wrapper
gradle run
## Compile only
./gradlew build
Kotlin/JVM Support
  • Kotlin 1.9+ (recommended)
  • JVM 17+ (required)
  • Kotlin 1.8+ (compatible)
Android Integration
This SDK works seamlessly with Android:
import okhttp3.OkHttpClient
import okhttp3.Request
class SafeSkyRepository(private val apiKey: String) {
    private val client = OkHttpClient()
    suspend fun getNearbyAircraft(lat: Double, lng: Double): List<Aircraft> {
        val url = "https://uav-api.safesky.app/v1/uav?lat=$lat&lng=$lng&rad=20000"
        val headers = SafeSkyHmacAuth.generateAuthHeaders(apiKey, "GET", url)
        val requestBuilder = Request.Builder().url(url)
            requestBuilder.addHeader(key, value)
        val response = client.newCall(requestBuilder.build()).execute()
        return if (response.isSuccessful) {
            Json.decodeFromString(response.body?.string() ?: "[]")
        } else {
            emptyList()
Ktor Integration
import io.ktor.client.*
import io.ktor.client.request.*
suspend fun getNearbyAircraft(client: HttpClient, apiKey: String) {
    val url = "https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908"
    val response = client.get(url) {
            header(key, value)
Security Notes
  • Use BuildConfig or resources: Store keys securely in Android
Troubleshooting
Invalid Signature
Replay Attack Detected
Timestamp Out of Range
Dependencies
  • Kotlin Standard Library - Built-in
  • kotlinx-serialization-json - JSON serialization (for examples)
  • java.security - Built-in (SHA-256, HMAC)
  • java.net.http - Built-in JDK 11+ (HTTP client)
For questions or issues:
  • Email: support@safesky.app
