HMAC Auth SDK for Dart
SafeSky HMAC Authentication SDK for Dart
Dart SDK for authenticating requests to the SafeSky API using HMAC-SHA256 signatures.
API Endpoint: All requests use https://uav-api.safesky.app. Each API key is associated with either a sandbox or production environment. The gateway automatically routes your request to the correct backend based on the environment configured for your API key.
Installation
Add to your pubspec.yaml:
dependencies:
  crypto: ^3.0.3
  uuid: ^4.0.0
  http: ^1.1.0  ## For HTTP requests (optional)
Then run:
dart pub get
Quick Start
import 'package:http/http.dart' as http;
import 'safesky_hmac_auth.dart';
void main() async {
  // Your SafeSky API key
  const apiKey = 'YOUR_SAFESKY_API_KEY_HEREHere';
  final headers = generateAuthHeaders(
    apiKey,
    'GET',
    'https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908',
  // Make authenticated request
  final response = await http.get(
    Uri.parse('https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908'),
    headers: headers.toMap(),
  print(response.body);
Usage Examples
The SDK includes 4 complete examples in example.dart:
Example 1: GET Request
Future<void> getNearbyAircraft() async {
  const apiKey = 'YOUR_SAFESKY_API_KEY_HERE';
  const url = 'https://uav-api.safesky.app/v1/uav?lat=50.6970&lng=4.3908&rad=20000';
  // Generate auth headers
  final authHeaders = generateAuthHeaders(apiKey, 'GET', url);
  // Make request
    Uri.parse(url),
    headers: {
      ...authHeaders.toMap(),
  print('Status: ${response.statusCode}');
  print('Body: ${response.body}');
Example 2: POST Request
import 'dart:convert';
Future<void> postUavPosition() async {
  const url = 'https://uav-api.safesky.app/v1/uav';
  final bodyData = [
      'id': 'my_uav_001',
      'altitude': 110,
      'latitude': 50.69378,
      'longitude': 4.39201,
      'last_update': DateTime.now().millisecondsSinceEpoch ~/ 1000,
      'status': 'AIRBORNE',
      'call_sign': 'Test UAV',
      'ground_speed': 10,
      'course': 250,
      'vertical_rate': 5,
  final body = jsonEncode(bodyData);
  final authHeaders = generateAuthHeaders(apiKey, 'POST', url, body: body);
  // Make request
  final response = await http.post(
    Uri.parse(url),
    headers: {
    body: body,
Future<void> postAdvisory() async {
  const url = 'https://uav-api.safesky.app/v1/advisory';
  final timestamp = DateTime.now().millisecondsSinceEpoch ~/ 1000;
  final bodyData = {
    'type': 'FeatureCollection',
    'features': [
        'type': 'Feature',
        'properties': {
          'id': 'my_advisory_id1',
          'max_altitude': 111,
          'last_update': timestamp,
          'call_sign': 'Advisory test with polygon',
          'remarks': 'Inspection powerlines',
        'geometry': {
          'type': 'Polygon',
          'coordinates': [
              [4.3948, 50.6831], [4.3952, 50.6832],
              // ... more coordinates ...
              [4.3948, 50.6831],
        'type': 'Feature',
        'properties': {
          'id': 'my_advisory_id2',
          'max_altitude': 150,
          'max_distance': 500,
          'call_sign': 'Advisory test with a point',
          'remarks': 'Inspection rails',
        'geometry': {
          'type': 'Point',
          'coordinates': [4.4, 50.7],
    Uri.parse(url),
    headers: {
    body: body,
void manualAuthentication() {
  // Step 1: Derive KID
  final kid = deriveKid(apiKey);
  print('KID: $kid');
  // Step 2: Derive HMAC key
  final hmacKey = deriveHmacKey(apiKey);
  final timestamp = generateTimestamp();
  final nonce = generateNonce();
  final canonicalRequest = buildCanonicalRequest(
    'GET',
    '/v1/uav',
    'lat=50.6970&lng=4.3908',
    'uav-api.safesky.app',
    timestamp,
    nonce,
  // Step 5: Generate signature
  final signature = generateSignature(canonicalRequest, hmacKey);
  print('Signature: $signature');
API Reference
Main Functions
generateAuthHeaders(apiKey, method, url, {body = ''})
Parameters:
  • url (String): Full request URL including protocol, host, path, and query string
  • body (String, optional): Request body for POST/PUT requests (default: empty string)
Returns: SafeSkyAuthHeaders containing all required headers
  'YOUR_SAFESKY_API_KEY_HERE',
  'POST',
  'https://uav-api.safesky.app/v1/uav',
  body: jsonEncode({...}),
SafeSkyAuthHeaders Class
Container for authentication headers with convenience methods.
Properties:
  • authorization (String): Authorization header value
  • xSsDate (String): X-SS-Date header value
  • xSsNonce (String): X-SS-Nonce header value
  • xSsAlg (String): X-SS-Alg header value
Methods:
  • toMap() → Map<String, String>: Convert headers to Map for HTTP requests
Helper Functions
deriveKid(apiKey) → String
deriveHmacKey(apiKey) → Uint8List
generateNonce() → String
generateTimestamp() → String
Format: YYYY-MM-DDTHH:MM:SS.sssZ
buildCanonicalRequest(...) → String
Parameters:
  • path (String): Request path
  • queryString (String): Query string without leading ?
  • host (String): Host header value
  • timestamp (String): ISO8601 timestamp
  • nonce (String): Unique nonce
  • body (String): Request body
generateSignature(canonicalRequest, hmacKey) → String
Authentication Flow
  5. Build Canonical Request:
    METHOD
    /path
    query_string
    host:hostname:port
    x-ss-date:timestamp
    x-ss-nonce:nonce
    body_hash_sha256_hex
Running Examples
## Install dependencies
dart pub get
## Run examples
dart run example.dart
Flutter Integration
This SDK works seamlessly with Flutter:
import 'package:safesky_hmac_auth/safesky_hmac_auth.dart';
class SafeSkyService {
  final String apiKey;
  SafeSkyService(this.apiKey);
  Future<List<dynamic>> getNearbyAircraft(double lat, double lng) async {
    final url = 'https://uav-api.safesky.app/v1/uav?lat=$lat&lng=$lng&rad=20000';
    final headers = generateAuthHeaders(apiKey, 'GET', url);
      Uri.parse(url),
    if (response.statusCode == 200) {
      return jsonDecode(response.body) as List;
    throw Exception('Failed to load aircraft');
Security Notes
  • Use environment variables: Store keys securely
  • HTTPS only: Always use HTTPS (uav-api.safesky.app)
Troubleshooting
Invalid Signature
Replay Attack Detected
Timestamp Out of Range
Dependencies
  • crypto: ^3.0.3 - Cryptographic operations (SHA-256, HMAC)
  • uuid: ^4.0.0 - UUID v4 generation for nonces
  • http: ^1.1.0 - HTTP client (optional, for examples)
For questions or issues:
  • Email: support@safesky.app
