Advisory UAV operations
The SafeSky API provides features to push the publication of active UAV activity areas, when no live telemetry is available.
Endpoint: POST /v1/advisory
Description: Publish one or more UAV active activity areas to the SafeSky platform. When an area is not active any more, simply stop pushing it. The POST frequency for advisory messages should one minute.
  • x-api-key: <your_api_key>
Example 1: Publishing a Polygon Advisory
GeoJSON Example:
        "id": "Advisory123",
        "call_sign": "UAV_Alpha",
        "last_update": 1738142598,
        "max_altitude": 150,
        "remarks": "Surveying area"
        "coordinates": [
            [4.39201, 50.69378],
            [4.39300, 50.69400],
            [4.39400, 50.69500],
            [4.39201, 50.69378]
Example 2: Publishing a Point Advisory with a Radius
Instead of a polygon, a point can be used to represent a UAV operation with a maximum radius max_distance.
GeoJSON Example:
        "id": "my_advisory_id2",
        "max_distance": 500,
        "remarks": "Inspection rails"
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
Example 3: Publishing Multiple Advisories Simultaneously
  • A polygon-based advisory representing an inspection area.
  • A point-based advisory with a specified radius.
        "id": "my_advisory_id1",
        "max_altitude": 111,
        "last_update": 1738142590,
        "coordinates": [
            [4.39201, 50.69378]
        "type": "Point",
        "coordinates": [
          4.4,
          50.7
id string Yes A unique identifier for the advisory message.
call_sign string No The call sign associated with the UAV operation.
last_update long Yes The timestamp of the last update in seconds since epoch (UTC-0).
max_altitude int Yes The maximum altitude (in meters AMSL) for operations.
remarks string No Free text comments providing additional info.
max_distance int Yes (Point) The radius (in meters) for point-based advisories.
  • 201 Created: Advisory information published successfully.
  • 400 Bad Request: Invalid parameters or failed authentication.
Notes:
  • Ensure that the coordinates for a polygon form a closed loop by repeating the first coordinate at the end of the array.
  • When using a point, the max_distance property is required to define the radius of operation.
