4 - Fly with your navigation software
1 - SkyDemon
2 - SDVFR
Steps to Connect:
- Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot. HotSpot should start with "AERO"
- Open SDVFR and go to Settings.
- Under Options, configure the traffic source to GDL90.
- If your Aero Tracker is placed outside and has GPS fix, you should see traffic appear in the list, similar to the screenshot below.
- Return to the main screen of SDVFR: nearby traffic should now be displayed on the map.
3 - SDVFR Next
Steps to Connect:
- Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot (name starts with "AERO").
- Open SDVFR Next and go to Settings.
- In the Réseau section, tap Source externe de trafics.
- Enable GDL90 as the
protocol.protocol: the "Status" should turn from red to green - Set the horizontal filter to your desired range and the vertical filter to your desired altitude
- Return to the main map screen: nearby traffic from both LTE and air-to-air sources should now be displayed.
4 - Other Navigation Software
Steps to Connect:
