4 - Fly with your navigation software
1 - SkyDemon
  1. Go to Navigation Options.
  2. Ensure “Show Bearingless Targets” is enabled.
2 - SDVFR
Steps to Connect:
  1. Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot. HotSpot should start with "AERO"
  2. Open SDVFR and go to Settings.
  3. Under Options, configure the traffic source to GDL90.
  4. If your Aero Tracker is placed outside and has GPS fix, you should see traffic appear in the list, similar to the screenshot below.
  5. Return to the main screen of SDVFR: nearby traffic should now be displayed on the map.
3 - SDVFR Next
Steps to Connect:
    Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot (name starts with "AERO"). Open SDVFR Next and go to Settings. In the Réseau section, tap Source externe de trafics. Enable GDL90 as the protocol. Set the horizontal filter to your desired range and the vertical filter to your desired altitude Return to the main map screen: nearby traffic from both LTE and air-to-air sources should now be displayed.
    4 - Other Navigation Software
    Steps to Connect:
    1. Ensure your Aero Tracker is in Wi-Fi mode.
    2. Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot.
    3. In your navigation software, configure the traffic source to GDL90.
    1. Open the SafeSky App and navigate to "My Devices".
    2. In the "External Devices" section, ensure your Aero Tracker shows a connected status via Bluetooth.
    3. Use the dropdown menu to view your configured aircraft in SafeSky.
    4. Select the desired aircraft from the list to update your Aero Tracker identity.
