4 - Fly with your navigation software
1 - SkyDemon
2 - SDVFR
Steps to Connect:
- Connect your phone or tablet to the Aero Tracker’s Wi-Fi hotspot. HotSpot should start with "AERO"
- Open SDVFR and go to Settings.
- Under Options, configure the traffic source to GDL90.
- If your Aero Tracker is placed outside and has GPS fix, you should see traffic appear in the list, similar to the screenshot below.
- Return to the main screen of SDVFR: nearby traffic should now be displayed on the map.
3 - Other Navigation Software
Steps to Connect:
