4 - FAQ
1 - Software update is not working?
It's possible that the Aero Tracker you have received contains an older firmware. You need to update it manually once for all:
  • Turn off the Aero Tracker
  • download the firmware manually fromĀ here
  • extract the SD card from the Aero Tracker and connect it to a computer
  • copy the file to the root of the SD card
  • rename the file to firmware.bin
  • Put the SD card back in the Aero Tracker, and power it on
The update should be complete.
