3 - Software update
How to Update the Aero-Tracker Firmware
To update the aero-tracker firmware, follow these steps:
  1. Ensure the aero-tracker is in Wi-Fi mode (instead of Bluetooth mode).
    • Quickly double-tap the power button to switch between modes.
  2. Connect your phone to the Aero-Tracker Wi-Fi network.
    • The system will check for any available software updates.
  3. If an update is available, you will see an "Update available" button.
    • Simply click it and follow the on-screen instructions to complete the update.
What to Do If You're Running an Older Firmware?
If your aero-tracker firmware is too outdated to update over Wi-Fi, follow these manual steps:
  1. Remove the SD card from the tracker.
  2. Download the base firmware from the following link:
    Download Firmware
  3. Copy the downloaded firmware.bin file to the root directory of the SD card. The SD card filename must be named firmware.bin
  4. Reinsert the SD card into the tracker and power it on.
    • The tracker should automatically detect and apply the firmware update.
  5. Once the base firmware is installed, follow the instructions above to update to the latest version using the standard Wi-Fi method.
