What will you get?
SafeSky collects and displays traffic data from 30+ different protocols and sources, including ADS-B, FLARM, OGN, and partially Mode S. As such, using SafeSky can give you at least "30 times more" traffic information, including exceptional traffic such as paramotor and drone traffic. Of course, if other pilots aren’t using any detection device, SafeSky, like any other system, will not be able to see them. It’s like driving a car: if you do not turn on your headlights at night you cannot be seen … or too late.
1. Radio protocols:
  • ADS-B
  • ADS-L
  • Asterix
  • Fanet
  • Flarm
  • Fly master
  • Flying Neurons
  • InReach
  • Microtrack
  • Mode S
  • Navigate
  • OGN tracker
  • Pilot Aware
  • SafeSky
  • Spider
  • Spot
  • XC-Guide
  • Navigation software:  EasyVFR and  and Air Navigation Pro software is natively integrated with SafeSky and provides thousands of additional pilots
  • Paramotor and paraglider portable hardware:  SkyTraxx,  Syride and  and FlyMaster  are natively integrated with SafeSky, providing a large picture of free flight traffic
  • Paramotor and paraglider software: Gaggle,  eVario,  XCTrack,  theFlightVario,  WingIt, AirSports.no  are natively integrated with SafeSky
Forewarned is forearmed.  If this traffic would come to close, you will get an an alert (visual or audible).
SafeSky offers both Free and a PREMIUM plan. The Free Plan includes all safety features, including traffic information. The PREMIUM Plan offers added comfort and compatibility, particularly with navigation software and connectivity to your devices.
