What will you get?
SafeSky collects and displays traffic data from 30+ different protocols, including ADS-B, FLARM, OGN, and partially Mode S. As such, using SafeSky can give you at least "30 times more" traffic information, including exceptional traffic such as paramotor and drone traffic. Of course, if other pilots aren’t using any detection device, SafeSky, like any other system, will not be able to see them. It’s like driving a car: if you do not turn on your headlights at night you cannot be seen … or too late.
1. Radio protocols:
  • ADS-B
  • ADS-L
  • Asterix
  • Fanet
  • Flarm
  • Fly master
  • Flying Neurons
  • InReach
  • Microtrack
  • Mode S
  • Navigate
  • OGN tracker
  • Pilot Aware
  • SafeSky
  • Spider
  • Spot
  • XC-Guide
  • Navigation software: EasyVFR and Air Navigation Pro software is natively integrated with SafeSky and provides thousands of additional pilots
  • Paramotor and paraglider portable hardware: SkyTraxxSyride and FlyMaster are natively integrated with SafeSky, providing a large picture of free flight traffic
  • Paramotor and paraglider software: GaggleeVarioXCTracktheFlightVarioWingIt, AirSports.no are natively integrated with SafeSky
