IOS Devices
iOS 13 and above Instructions
1.
    Go to “Settings” then “WiFi” 2. Connect to your WiFi network 3. Click the Info (i) icon next to your current WiFi network to view network info 4. Make note of your IP Address and Subnet Mask 5. Change “Configure IP” from “Automatic” to “Manual” and enter the IP Address and Subnet Mask. DO NOT CONFIGURE ROUTER. The “Router” setting should be BLANK/EMPTY! 6. Save your changes. iOS will show “No Internet Connection” next to your WiFi device. iOS should no longer attempt to connect to Internet through this WiFi network.
    Android Devices
    On Android > 11, it should be working out of the box. Android should detect that no internet connection is available on the WiFi, and prompt you to use your SIM data instead.
    1.
      Go to Settings > Connections > WiFi 2. Tap and hold your WiFi network name until a menu appears 3. Click “Manage Network Settings” 4. Make note of your IP Address and Subnet Mask 5. Change “IP Settings” from “DHCP” to “Static” 6. Remove the IP address from “Gateway” so that “Gateway” is blank. 7. DO NOT CHANGE any other settings. Be sure to leave “IP Address” or “Network Prefix Length” alone. The “Router” setting should be BLANK/EMPTY! 8. Save your changes. Android should no longer attempt to connect to Internet through this WiFi network
      Recent versions of Android OS also allow users to force the OS to always use Mobile Data. **This is not as ideal as the iOS settings above, so only use as a last resort.** You must toggle this setting whenever you DO want to use a WiFi Internet Connection.
      Enable Developer Mode
      1.
        Go to Settings > System > About Phone 2. Tap “Build Number” until Developer Mode is enabled
        **Toggle Mobile Data Setting
        Setting**
        1.
          Go to Settings > System > Developer Options 2. Toggle “Mobile Data Always Active”
          1.
            Go to Settings > About Phone > Software Information 2. Tap “Build Number” (~7 times) until “Developer Mode has been turned on” is displayed
            Setting**
            1.
              Go to Settings > Developer Options > Network 2. Toggle “Keep Mobile data turned on”
              Android (version 10, 11, 12, 13, 14, 15, 16+)
              On newer Android versions, the operating system prioritises Wi-Fi when connected. If the Wi-Fi network (e.g., SkyEcho2/Stratux/PowerFLARM hotspot) has no Internet, Android may still try to route all traffic over Wi-Fi and not fall back to mobile data unless you change a few settings. This behaviour varies by manufacturer (Samsung, Xiaomi, etc.) and OS version.
              Goal: Stay connected to the device’s Wi-Fi hotspot for data exchange while the phone uses 4G/5G for Internet.
              1) Samsung / One UI: force an app to use mobile data
              On Samsung devices you can force specific apps to use mobile data even when Wi-Fi is connected.
              Path: Settings → Connections → Data usage → Mobile data only apps (or Allowed networks for apps) → enable it for SafeSky.
              This is the cleanest approach on Samsung, though some users report inconsistencies across models/updates.
                Guidance / tip article (Samsung One UI): Community note about bugs/limits:
                2) Keep mobile data active (Developer Options)
                Ensures mobile data remains available while you’re on Wi-Fi.
                  Enable Developer Options: Settings → About phone → (tap) Build number ×7. Go to Settings → System → Developer options and enable “Mobile data always active” (wording may vary).
                  This helps some devices keep both interfaces up so Android can route/fallback as needed. (Availability/wording differs by OEM/OS.)
                  3) Intelligent Wi-Fi / Auto-switch settings (Samsung)
                  Samsung includes “Intelligent Wi-Fi” features that switch between Wi-Fi and mobile data. Disable these so Wi-Fi stays connected to the device hotspot without Android trying to drop it:
                  Settings → Connections → Wi-Fi → (⋮) → Intelligent Wi-Fi → turn off options like “Switch to mobile data” or “Auto switch to mobile data”.
                  4) Connect to the device hotspot and allow “No Internet”
                  When you join the external device’s SSID, Android may show “This network has no Internet”.
                    Choose “Connect anyway” / “Stay connected” so the OS keeps the Wi-Fi link purely for local data while mobile Internet remains available. On some devices there’s also a per-network option like “Use this network even without Internet” in the advanced Wi-Fi settings.
                    Other cases
                    If none of the above scenario is working, the combination between your phone manufacturer, operating system version and the extra software layer of your vendor is going to make things specific.
