IOS Devices
iOS 13 and above Instructions
Android Devices
On Android > 11, it should be working out of the box. Android should detect that no internet connection is available on the WiFi, and prompt you to use your SIM data instead.
Enable Developer Mode
Android (version 10, 11, 12, 13, 14, 15, 16+)
On newer Android versions, the operating system prioritises Wi-Fi when connected. If the Wi-Fi network (e.g., SkyEcho2/Stratux/PowerFLARM hotspot) has no Internet, Android may still try to route all traffic over Wi-Fi and not fall back to mobile data unless you change a few settings. This behaviour varies by manufacturer (Samsung, Xiaomi, etc.) and OS version.
Goal: Stay connected to the device’s Wi-Fi hotspot for data exchange while the phone uses 4G/5G for Internet.
1) Samsung / One UI: force an app to use mobile data
On Samsung devices you can force specific apps to use mobile data even when Wi-Fi is connected.
Path: Settings → Connections → Data usage → Mobile data only apps (or Allowed networks for apps) → enable it for SafeSky.
This is the cleanest approach on Samsung, though some users report inconsistencies across models/updates.
- Guidance / tip article (Samsung One UI):
- Community note about bugs/limits:
2) Keep mobile data active (Developer Options)
Ensures mobile data remains available while you’re on Wi-Fi.
- Enable Developer Options:
Settings → About phone → (tap) Build number ×7. - Go to
Settings → System → Developer optionsand enable “Mobile data always active” (wording may vary).
This helps some devices keep both interfaces up so Android can route/fallback as needed. (Availability/wording differs by OEM/OS.)
3) Intelligent Wi-Fi / Auto-switch settings (Samsung)
Samsung includes “Intelligent Wi-Fi” features that switch between Wi-Fi and mobile data. Disable these so Wi-Fi stays connected to the device hotspot without Android trying to drop it:
Settings → Connections → Wi-Fi → (⋮) → Intelligent Wi-Fi → turn off options like “Switch to mobile data” or “Auto switch to mobile data”.
4) Connect to the device hotspot and allow “No Internet”
When you join the external device’s SSID, Android may show “This network has no Internet”.
- Choose “Connect anyway” / “Stay connected” so the OS keeps the Wi-Fi link purely for local data while mobile Internet remains available.
- On some devices there’s also a per-network option like “Use this network even without Internet” in the advanced Wi-Fi settings.
Other cases
If none of the above scenario is working, the combination between your phone manufacturer, operating system version and the extra software layer of your vendor is going to make things specific.
