IOS Devices
iOS 13 and above Instructions
Android Devices
On Android > 11, it should be working out of the box. Android should detect that no internet connection is available on the WiFi, and prompt you to use your SIM data instead.
  8. Save your changes. Android should no longer attempt to connect to Internet through this WiFi network.network
Enable Developer Mode
Toggle Mobile Data Setting
Other cases
If none of the above scenario is working, the combination between your phone manufacturer, operating system version and the extra software layer of your vendor is going to make things specific.
