IOS Devices
iOS 13 and above Instructions
Android Devices
Enable Developer Mode
Toggle Mobile Data Setting
The stratuxStratux team has made a specific workaround if none of the above is working:
https://github.com/b3nn0/stratux/wiki/Wifi-Direct-and-Android-mobile-data-while-connected-to-Stratuxworking.
Other cases
