When tryingattempting to connect an external device such aslike a SkyEcho2, a StratuxStratux, or a PowerFLARM,PowerFLARM to your phone, you need to ensure that your phone must beis connected to the external devicedevice's WifiWi-Fi hotspot while also having internet routingaccess though thethrough 4G/5G mobile datadata.
IOS Devices
iOS 13 and above Instructions
Android Devices
Enable Developer Mode
Toggle Mobile Data Setting
Other cases
