When trying to connect an external device such as a SkyEcho2, a Stratux or a PowerFLARM, your phone must be connected to the external device Wifi hotspot while having internet routing though the 4G/5G mobile data access.
IOS Devices
iOS 13 and above Instructions
Android Devices
Enable Developer Mode
Toggle Mobile Data Setting
