Are youWhen trying to connect an external device such as a SkyEcho2, a Stratux or a PowerFLARM, your mobile phone ormust otherbe connected to the external device withWifi hotspot while having internet routing though the 4G/5G mobile data access to a WiFi network or WiFi-enabled device that does not have Internet access? Would you like to force the device to use your Mobile Internet connection even if your WiFi network has Internet access?
Situations might include connecting directly to a camera that broadcasts a WiFi network or controlling your smart home devices after cancelling your home internet service.
Great news! This CAN be done. See below for instructions for iOS devices (iPhone or iPad) and Android devices (Samsung Galaxy, Google Pixel, etc)access.
IOS Devices
NOTE:This iOSshould 12be /working out of the box.
iOS 13 /and iOSabove 14 maywill automatically detect that your WiFi network does NOT have Internet and allow you to access other devices on the WiFi network while automatically using your mobile Internet. If not, you can follow these steps to FORCE iOS to use mobile Internet while connected to a WiFi network.
iOS 12 / iOS 13 / iOS 14 Instructions (use mobile data for specific WiFi network)
Android Devices
Enable Developer Mode
Toggle Mobile Data Setting
