Frequently Asked Questions
Configuration
Absolutely!
You have two options:
LINK TO MANUAL
That's simple.
LINK TO MANUAL
That's easy.
LINK TO MANUAL
If your aircraft is equipped with a radio transmitting device (such as an ADS-B out transponder, FLARM, SkyEcho) your signal is picked up by ground stations, shared with SafeSky servers, and retransmitted to you. SafeSky automatically detects this double echo in flight and asks you to confirm it's your aircraft. Otherwise, you can simply add your hexadecimal code in SafeSky. You can do this manually under "PreferencesSettings > My Aircraft > Enter your Callsign > Turn on the Transponder button," and the hexadecimal code will be updated automatically. Note that all your external devices must be configured with the same hexadecimal code.
To activate the 'Approach' mode, simply go to 'Preferences-Settings >Map-Maps > Manage Countries'countries' and download the countries you want to activate.
LINK TO MANUAL
Functioning
  • In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 50005,000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
  • SafeSky's audiencecommunity is mostly pilots flying in E and G airspace classes up to 50005,000 feet AGL. Above that, pilots usually fly in a different airspace.
With over 40,50,000 pilot-users in our community, there is a good chance that your fellow pilots are using SafeSky. However, even if they would not be using it, there is definitely added-value for you. SafeSky collects traffic data from close to 20 other sources besides SafeSky, so we – and thus you as well when using SafeSky - can still see other aircraft even if they are not using SafeSky and alert them about potential traffic conflicts.
That's possible.
It is very low.
  • Plug in a charger
How to unsubscribe?
Compatibility
Yes and No.
Plan PREMIUM required.
LINK TO MANUAL
  • Android 6 + 2GB RAM minimum
  • Apple iOS 13 minimum
LINK TO MANUAL
