Frequently Asked Questions
Configuration
Absolutely!
You have two options:
LINK TO MANUAL
That's simple.
It's essential to have the same unique ICAO hexadecimal code on all your devices. To do so, simply enter it in SafeSky under "Preferences > My Aircraft > Enter your Callsign > Turn on the Transponder button", and the updated code will automatically appear. It's important to remember to configure all your external devices (such as FLARM, PilotAware, SkyEcho, Stratux, etc.) with the same code.
That's easy.
Functioning
In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
SafeSky's audience is mostly pilots flying in E and G airspace classes up to 5000 feet AGL. Above that, pilots usually fly in a different airspace.
That's possible.
It is very low.
- Plug in a charger
How to unsubscribe?
Compatibility
Yes and No.
Android 6 + 2GB RAM minimum
Apple iOS 13 minimum
