Frequently Asked Questions
Configuration
Absolutely!
You have two options:
That's simple.
It's essential to have the same unique ICAO hexadecimal code on all your devices. To do so, simply enter it in SafeSky under "Preferences > My Aircraft > Enter your Callsign > Turn on the Transponder button," and the updated code will automatically appear. It's important to remember to configure all your external devices (such as FLARM, PilotAware, SkyEcho, Stratux, etc.) with the same code.
That's easy.
Functioning
  • In Europe, the internet coverage is generally good and SafeSky has a success rate of 86% for data transmission up to 5000 feet. There may be spots with no coverage, but SafeSky will reconnect automatically once the connection is restored.
  • SafeSky's audience is mostly pilots flying in E and G airspace classes up to 5000 feet AGL. Above that, pilots usually fly in a different airspace.
You will get the most complete traffic information service in-flight. SafeSky collects and displays traffic data from almost 20 different protocols, including ADS-B, FLARM, OGN, and partially Mode S. While it may not show everything, it offers significantly more traffic information than a single system (even more than popular systems like Flightradar24) or no system at all, without any extra hardware or financial cost. Using SafeSky can give you at least "20 times more" traffic information, including exceptional traffic such as paramotor traffic. Of course, if other pilots aren’t using any detection device, SafeSky, like any other system, will not be able to see them. It’s like driving a car: if you do not turn on your headlights at night you cannot be seen … or too late.
Weather reports (METAR) are available in the PREMIUM plan. They are accessible during your entire flight, indicating for each upcoming destination the weather you can expect.
That's possible.
It is very low. On average, traffic data consumption for one hour of flight is about 2 MB.
o Use the SafeSky filters to only transmit the data you really need
o Plug in a charger
o Foresee an additional external mobile battery
How to unsubscribe?
Compatibility
Yes and No.
Plan PREMIUM required.
  • Android 6 + 2GB RAM minimum
  • Apple iOS 13 minimum
